the final problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=43914
Printed Date: April 09, 2026 at 3:14 AM
Topic: the final problem
Posted By: jeffchilcott
Subject: the final problem
Date Posted: November 27, 2004 at 3:58 PM
ok everything works, kinda....when you go to remote start the car..quite often it wont start...If you put the key in go to acc, and remote start it starts...tkae key out and shut off via remote.   it will re start via remote a few times and others it wont, I checked all connections and all are good, I can continue to reinsert the key and remote start and such and it keeps doing the same thing,   when it wont start the starter wont crank
2001 buick regal, viper 791xv, PLDATA bypass
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Posted By: draasch
Date Posted: November 27, 2004 at 4:02 PM
just put the key in the ign. ....do not turn the key and see if it remote starts .......if it does, then the by-pass is not working.........if it will only start with the key turned, then you dont have the right ign. wire hooked up........................
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
