92 ford probe remote start Python 881xp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=44181
Printed Date: April 18, 2026 at 10:46 PM
Topic: 92 ford probe remote start Python 881xp
Posted By: viccari_jeremy
Subject: 92 ford probe remote start Python 881xp
Date Posted: November 30, 2004 at 11:11 PM
Hey there.
            First off, thank you for your diagrams and existence. Secondly, I have the alarm installed with all triggers, hood pin, remote sattelite relay. I also wired up the power door locks, using a 4.7 kohm resistor as in the diagram I obtained from the dealer of the alarm.
            I hooked up the tach wire, and I am unsure if it is the correct wire, I used yellow/blue at the ignition coil. Also, since my car is a manual transmission, I have great concern about the remote start unit. I would like to have it working, as I am taking a trip to the East coast, and it would be nice to be warm when I get in the car.
            I heard I need an additional module to get this to work in my manual trans car. It is a 3.0 L model.
            I was going to do the neutral saftey switch, but that is different in my manual, it is located at the clutch. I have never set this up before, and want to be extremely careful with this aspect of the install. My diagram does not contain the wires needed to hook this up correctly. If I need an additional module, which part number do I need. Is it possible to get a better diagram of Vehicle wiring for my ford probe. At least I got this far. :) Your diagram for the door locks was spot on.
Thank you all for your time and support.
Jeremy
92 ford probe 3.0L LX
DEI Python 881xp
Date Posted: November 30, 2004 at 11:13 PM
Location of the neutral saftey switch is at the Clutch pedal. Unless depressed, no crank.
Date Posted: November 30, 2004 at 11:22 PM
I printed the diagram for 92 ford probe from your site. Thank you for that.
However I am curious about the following.
Neutral saftey switch - Not grounding - OEM switch opens starter circuit.
Also I still don't know what else I need to get this hooked up.
Thanks again
Jeremy
