remote start for a 99 blazer
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=44246
Printed Date: April 18, 2026 at 7:48 PM
Topic: remote start for a 99 blazer
Posted By: jasgk
Subject: remote start for a 99 blazer
Date Posted: December 01, 2004 at 8:49 PM
I already have a Bulldog RS102 sitting in my closet. I was wondering if I can use the 3 pulse from the lock method of installation instead of tracking all the wires. It just seems redundant to track down and make connections to wires that are already being used for the same purposes. If the RS102 wont work is there a remote start add on available and where could I find one?  Also is there a way to bypass the passlock security system without buying more modules. If all I need is a relay I have those coming out of my ears.
Thank you.
Jason
Posted By: Velocity Motors
Date Posted: December 01, 2004 at 8:55 PM
Hooking up the RS102 requires the same wires as if you were to install a normal remote start system. The only difference is that the keyless entry is not required for the RS102 and your range is only as good as the factory remote FOB allows. If you don't want to buy an additional module for the Passlock bypass you can use this diagram:
GM Passlock II Bypass diagram
