99 Dodge Ram Door Lock Question
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=44250
Printed Date: April 18, 2026 at 6:02 AM
Topic: 99 Dodge Ram Door Lock Question
Posted By: NJNJ
Subject: 99 Dodge Ram Door Lock Question
Date Posted: December 01, 2004 at 9:50 PM
Im going to be doing a alarm/remote start in a 99 Dodge Ram and had some questions about the Door Lock/Unlock...
On here, it says that the Door Lock is a reverse polarity... While on Directtechs.com it shows both the unlock/lock wires as a 5 wire system.... I was to understand these are different wiring diagrams..... I am going to be using a crimestopper Cs2011Rs if that helps, can anyone tell me what actual diagram to use to wire the power door locks?
NJ
Posted By: dfiddy
Date Posted: December 01, 2004 at 10:25 PM
Directechs says that they are positive lock and 5 wire unlock. Just 5 wire both lock and unlock and be done with it. Much easier and you dont have to worry about wiring it wrong. Hope that helps.
Posted By: daniel2002p
Date Posted: December 01, 2004 at 10:28 PM
reverse polarity and 5 wire mean the same thing, you can use this diagram. https://www.the12volt.com/doorlocks/page3.asp#5w ------------- 2005 Toyota Corolla S
1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
Posted By: extreme1
Date Posted: December 01, 2004 at 11:15 PM
If the truck has a factory alarm, you can grab locks at the CTM (central timer module) it's right of the steering column. 1 wire (light GREEN/ orange) 644 ohms to lock, 1500 to unlock (two pulses) negative.
------------- Shaughn Murley
Visions Electronics
Red Deer, Alberta
Posted By: NJNJ
Date Posted: December 02, 2004 at 2:08 PM
Nah, the truck doesnt have a factory alarm, so that shouldnt be a problem
Thanks for the help guys!
