Problem remote starter
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=44323
Printed Date: April 17, 2026 at 3:21 PM
Topic: Problem remote starter
Posted By: ottawa m
Subject: Problem remote starter
Date Posted: December 02, 2004 at 9:45 PM
 I installed a prostart remote starter a little while ago in my 2002 calviler standard .It worked fine now it won't start . I can put it in ready mode but thats it .I here the fan and fuel pump come on but it won't crank .I checked my wires all are still connected . fuses are ok . Bypass works (   learning bypass). I am at a loss the manual gives no help I reset the module and still nothing .
Any help would be welcome Thanks in advance
Posted By: jrilla
Date Posted: December 02, 2004 at 9:53 PM
How did you bypass the clutch? Try sitting in the car with the clutch pedal depressed and see if that works. Then you know thats the problem.
J Rilla
Owner/Installer
Posted By: ottawa m
Date Posted: December 02, 2004 at 11:15 PM
I bypased the cluch using the starter wire from the remote  as it was a direct feed . I tried the pressing of the cluch and pressing the start still nothing .
Posted By: extreme1
Date Posted: December 02, 2004 at 11:21 PM
you have a blown fuse on one of your remote starters wires.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Posted By: daniel2002p
Date Posted: December 02, 2004 at 11:27 PM
put you DMM on the starter wire coming off of the alarm, and see if it shown 12v when cranking. if not that your alarm is bad or you have a blown fuse.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
Posted By: ottawa m
Date Posted: December 04, 2004 at 1:32 PM
 I checked all my connections fuses even replaced just to make sure. when I put it ready mode instead  of the parklight flashing three times it flashs about 5 or more before the lights stay on for ready mode . I exit the my car press the remote to turn it off . and when i press the  remote to turn on the park lights flash I here the going through the prep to start and then it stops and the park lights flash three times and thats it .
