2000 olds alero autostart?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=44389
Printed Date: April 17, 2026 at 3:41 PM
Topic: 2000 olds alero autostart?
Posted By: ottawaguy
Subject: 2000 olds alero autostart?
Date Posted: December 03, 2004 at 9:42 PM
Hi
 I am trying to intsall a auto start keyless entry system on a 2000 olds alero, trying to firgure whats the BCM? ON THESE WIRING DIAGRAMS? I Understand the rest pretty much i think i hook up the power locks using one wire system? where do i find the didode isolate door trigger locks?
 Can anyone help me   this my first time trying to install a system?
Kevin
K. form
Posted By: Velocity Motors
Date Posted: December 03, 2004 at 10:00 PM
The BCM is the WHITE plastic cover on the driver's side kick panel.
Posted By: sparkie
Date Posted: December 04, 2004 at 2:32 PM
I'm sorry but the BCM (Body Control Module) is actually under the passenger side dash. If you remove the underdash panel the BCM is the black box with all the plugs going into it. You can get the doorlock wires behind the carpet in the driver's kick panel. The main ignition and Passlock wires can be tied into easiest if you remove the instrument cluster and pull the ignition switch out through that area.
sparky
Posted By: arctic
Date Posted: December 04, 2004 at 4:45 PM
remove the instrument cluster? are you nuts? take out the radio... a panel tool and a couple of 7 mils. everything is right there.
