2004 neon engine light
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=44445
Printed Date: May 16, 2026 at 5:19 AM
Topic: 2004 neon engine light
Posted By: Falcon 1
Subject: 2004 neon engine light
Date Posted: December 04, 2004 at 6:53 PM
I installed a remote start in a 2004 dodge neon now I am getting the engine light staying on with remote or when started with key. I don't recall if the engine light was on before starting work on the car. Anyone have any ideas. Also its a bulldog remote starter.
Do it right the first time, only a doctor can bury his mistakes.
Posted By: SEXIFIED
Date Posted: December 04, 2004 at 7:09 PM
first have you powers all of the ignitions and the acc's?
if you did remove the (-) off the battery and let it sit for 20 min or so.
it should go away....providing it wasn't on before you began the install.
SWEET.
Posted By: Falcon 1
Date Posted: December 04, 2004 at 7:12 PM
I have wired all ignition wires and acc's to my knowledge. I will try disconnecting the battery.
Posted By: extreme1
Date Posted: December 04, 2004 at 8:51 PM
there is only one ign and one acc required on that car, pretty simple really.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Posted By: Falcon 1
Date Posted: December 04, 2004 at 9:08 PM
I disconnected the battery as Sexified suggested and the light is off and has not come back on even after taken the car for a ride. Thanks for your help.
Posted By: daniel2002p
Date Posted: December 04, 2004 at 11:14 PM
disconnect the alarm and see if it still does it.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
