arctic shark remote starters
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=44621
Printed Date: April 19, 2026 at 11:03 PM
Topic: arctic shark remote starters
Posted By: Dauber
Subject: arctic shark remote starters
Date Posted: December 06, 2004 at 10:40 PM
How to program the remotes, since it is an obsolete system, does anybody know?
Kyle@Audio Obsession Sound
Posted By: ck auto
Date Posted: December 07, 2004 at 12:35 AM
hi kyle arctic start is a brand distributed under r thibert in quebec it could be a compustar or auto start or just about any mainstream brand they just brand them under artic start you can get the new compustar 900mhz under the artic start badge
good luck
kirk
Posted By: Dauber
Date Posted: December 10, 2004 at 12:06 AM
ck auto, Arctic Shark is the name of the car starter, it was manufactured by a company by the name of Scotia which was a big hit in Edmonton, AB(Canada) and now I have a customer that I have a new remote for it but programming is unlike any system I have seen before, so.....I hope someone out there can help me if they know the system at all, thanks anyways though ck auto.
Posted By: budman1239
Date Posted: December 14, 2004 at 1:16 PM
Dauber, I also have a Scotia starter, that I need to re-program a remote. It's a Scotia Start 3000, Can anyone help!
Posted By: Dauber
Date Posted: December 16, 2004 at 12:06 AM
budman 1239, I found a solution to my problems so hopefully this programming will help you;    pop the hood and make sure there is ground going through the hoodpin to the brain, there will be no parklight confirmation so just twist it a few times then go inside your car, turn the ignition on, off 4 times and on the 4th time leave in the on position, parklights should come on, the press the lock button on the remote, turn the ignition off, hold the hoodpin down and see what happens, let me know if this helps!
Date Posted: December 16, 2004 at 6:24 PM
Dauber mine remote only has two buttons I and II, no lock/unlock, this is how I programmed mine,
          1. Open the Hood Pin Switch.
Before the 20 seconds have passed, turn the ignition key to the IGNITION ON (RUN) position and then to the OFF position.
  1. 2. Press and hold button É until the vehicle gives 5 flashes. The module has stored the transmitter in its memory.
  2. 3. Close the Hood, to exit.
