Disable trunk release button
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=44628
Printed Date: April 19, 2026 at 5:50 PM
Topic: Disable trunk release button
Posted By: 12vbattery
Subject: Disable trunk release button
Date Posted: December 07, 2004 at 12:41 AM
How would i go about disabling the internal trunk release button while the car is switched off? Would i need some sort of relay?
The reason i want to do this is to prevent theives from smashing the window and having instanc access to whatever i have in the trunk.
Posted By: 91cpe
Date Posted: December 07, 2004 at 12:49 AM
You could use a swtich to manually activate the button the easiest way, or you could use a relay wired off of something that is only on when the car is on.   Read up here https://www.the12volt.com/relays/relays.asp to get some good info about relays andhow to use them.
Posted By: mobile1
Date Posted: December 07, 2004 at 8:24 AM
what kind of vehicle??
Date Posted: December 07, 2004 at 8:39 AM
Its a 1992 EB Ford Fairmont (Australian car)
