window relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=4472
Printed Date: March 27, 2026 at 7:45 AM
Topic: window relays
Posted By: jokerschild275
Subject: window relays
Date Posted: October 14, 2002 at 7:59 PM
Ok heys what i want to do. I want to roll my windows up and down with my remote I am going to use 2 chs on my alarm to do so. I have 4 windows and i want them all to do the sme thing. I figured out how i was going to make the relays work but what can i use to shut the relay off after the window closes. The windows will be on a timer but i can only set the timer in 10 sec intervals. so the windows will still try to roll up even thought they are already rolled up untill the timer quits. and evently this would probably tear up something...... thanks chris
Posted By: securinu
Date Posted: October 14, 2002 at 8:54 PM
break down and buy a window mod you can get one for $20 or so on ebay
Posted By: djfearny2
Date Posted: October 14, 2002 at 9:11 PM
and if you know anyone at a shop you can do the same how many windows if you want four windows youwill need two dei 530t window mods one for up and down in front and one up and down for back.
------------- Jon
Installer/Help Technician
---coral springs florida---
Posted By: Ohmz
Date Posted: October 14, 2002 at 11:05 PM
I agree, buy 2 4window roll up module. Relays were used back in the days and are just so confusing sometimes. It'll be messy and hard to find a place for all those relays.
Date Posted: October 15, 2002 at 6:39 AM
all right thanks guys, i didnt know that they made a module that did up and down for two windows. i thought that i was going to have to buy 4 of the oneway modules for 2 windows.
Date Posted: October 15, 2002 at 11:36 AM
ok got another ?, can I wire all for window to one 2 window up/down module by adding a relay or something.
Posted By: go2pac
Date Posted: October 15, 2002 at 11:58 AM
It can be done but you would need a handfull of relays to do it and maybe a timer/latch module if you are only using two channels. You are better of with 2 window modules like DEI's 530T which will give you one touch up/down for all four windows and window crack using one channel.
------------- Karl
Pacific Accessory Corporation
Mobile Audio Interfacing Equipment
Connecting You to Your Music Since 1976
