About toyota sienna 1998
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=44782
Printed Date: May 03, 2026 at 11:00 AM
Topic: About toyota sienna 1998
Posted By: madBedex
Subject: About toyota sienna 1998
Date Posted: December 09, 2004 at 6:02 AM
Hi! guys
 I know this is a funny question.
 What is the difference between door trigger and a domelight when you probe them.The toyota sienna that i worked on has door trigger wire & also domelight wire.
Please,help would be greatly appreciated.
madbedex
Posted By: hagmanti
Date Posted: December 09, 2004 at 9:30 AM
Sometimes there is no difference-- the wire that turns on the domelight (by going to ground) is an effective door trigger. In that car's case, I believe that the RED / green wire is for 2 of the doors, and the RED / yellow the other two, and if you jump either to ground, the domelight comes on. However, I haven't been in one real recently, so check that w/ your trusty DMM!
Me, who also suggests low amperage fuses in any testing...
