2000 honda accord r\s
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=45041
Printed Date: May 12, 2026 at 5:23 PM
Topic: 2000 honda accord r\s
Posted By: muaiad97
Subject: 2000 honda accord r\s
Date Posted: December 12, 2004 at 4:14 PM
hi  all
i have  honda accord 2000 i want install r\s but i want to know if the car need bypass unit  because i checket in the dash  ther is no any theft or security light comes on . if  the car need bypass  what kind i have to use
thanx
Posted By: daze
Date Posted: December 12, 2004 at 5:15 PM
if its a 2000 than i would think you need a bypass. It depends on the way the key is cut. Is it cut like a normal key or does it look a laser cut ?
Posted By: muaiad97
Date Posted: December 12, 2004 at 5:31 PM
YEA IT LOOKS LIKE  NORMAL KEY BUT WHEN I CHECKED THE WIRING DIAGRAM IT SAYS NEED BYPASS UNIT
Posted By: profuse007
Date Posted: December 12, 2004 at 5:57 PM
555H (no spare key required), or 555U (spare key needed).
use the search button for diagram or past threads on this car.
Houston,TX
