98 Mercury Mystique
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=45053
Printed Date: April 18, 2026 at 2:07 PM
Topic: 98 Mercury Mystique
Posted By: I420head
Subject: 98 Mercury Mystique
Date Posted: December 12, 2004 at 6:10 PM
I recently purchased an AutoPage 720LCD and I have everything working properly except the door locks. I think the car has positive trigger 2 step unlock. The manual gives the diagram for the proper relay setup, but I have to
tap into the unlock wire after the OEM Door lock relay and I don't know where that wire is at or what color it is. The car has factory keyless entry. Is there anyway to change the factory 2 step to single press unlock?
Posted By: furredoutgixxer
Date Posted: December 12, 2004 at 7:52 PM
high in drivers kick or at the keyless module located behind the glovebox, high in passenger kick panel. There are two yellow/purple wires - one unlocks drivers door and the other unlocks the rest of the doors. These two wires are common at rest through the keyless entry module. Diode isolate and pulse (+) to operate. Lock is WHITE/ purple at keyless module. May need relays. hope this helps.
MECP Master Installer
Posted By: I420head
Date Posted: December 13, 2004 at 8:11 AM
Is the WHITE/ purple wire your referring to on the passenger door lock motor side of the circuit? Thanks alot for the info.
