2002 Millenia and viper 791 xv
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=45097
Printed Date: April 18, 2026 at 3:56 PM
Topic: 2002 Millenia and viper 791 xv
Posted By: meh66
Subject: 2002 Millenia and viper 791 xv
Date Posted: December 13, 2004 at 8:16 AM
This car currently has a factory security system. I was not even able to get to the remote start portion as the info I had for this vehicle was not accurate. I had the info from DEI. I thought this vehiclearm/disarmed with the lock/unlock wire. The wires in the ignition harness was correct. This vehicle has progressive door locks. The documents I have say this is a single wire system, so I am confused how the viper alarm can do passenger door unlock on the second pulse if I am only tapping one wire. Below is the info I have:
Wire                                                          Remarks
door trigger                                             There were four light green wires in the large harness going to the rear of the vehicle and none was the trigger
lock/unlock                                               blue/orange in the passenger door harness - I could not find this wire, but I think I was frustrated at that point
Dome light supervison                          No clue where this wire is located
Trunk/hatch release                               My document said it was PURPLE / white, but I traced it and found it was BROWN / white.
These are the wires I could not accurately find. So any help would be appreciated. Should I use the ground when armed output wire from the alarm to the keysense wire or should I use the factory alarm disarm wire? Sorry for the long post, but I spent alot of hours on this vehicle and I am still not finished.
MEH66
"Car Performance and Mobile Electronic Enthusiats"
Posted By: snguyen
Date Posted: December 13, 2004 at 8:55 AM
Mazda
Millenia
2001-2002
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
BLACK / YELLOW
IGNITION SWITCH HARNESS *
Ignition  #1:
BLACK/ WHITE
Ignition #2:
BLACK/ RED
Ignition  #3:
N/A
Accessory:
BLUE
Brake  Light:
WHITE/ GREEN
AT SWITCH ABOVE BRAKE PEDAL
Tach  Signal:
GREEN/ BLUE
DIAGNOSTIC CONNECTOR DRIVER SIDE FIREWALL IN ENGINE
Parking Lights:
ORANGE (+)
DRIVER'S KICK PANEL
Headlights:
RED OR RED / BLUE (-)
STEERING COLUMN HARNESS
Diesel  Glow Plug:
Clutch  Bypass Wire:
Notes:
 * This Vehicle Is Equpped With A Transponder Type Theft System. See Installation Note #144 - Bypassing Transponder Theft Systems.
Mazda
Millenia
2001-2002
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
GREEN
OEM Alarm Disarm:
BLUE/BLACK (+)
KEY SENSE WIRE IN STEERING COLUMN HARNESS ***
Dome  Lights/Superv:
LT. GREEN (-)
DRIVER'S KICK PANEL
OEM Horn:
GREEN/ RED (-)
Power  Lock:
BLUE/RED OR ORANGE
PASSENGER KICK COMING IN FROM DOOR HARNESS **
Power  Unlock:
BLUE/RED OR ORANGE
Trunk  Release:
BROWN / WHITE (+)
DRIVER'S KICK COMING IN FROM DOOR HARNESS
Alarm  Input Wire:
LT. GREEN (-)
DRIVER'S KICK PANEL
Notes:
**See Note #201 Negative Trigger Door Locks. Reistor values not available. Must measure The door switch with switch unplugged from vehicle to obtain the correct values.
Posted By: meh66
Date Posted: December 13, 2004 at 9:01 AM
Hey thanks.... I notice the keysense wire is positive...so do I have to change the polarity from the alarm since the the disarm output is negative?
MEH66
Posted By: hagmanti
Date Posted: December 13, 2004 at 10:11 AM
That is correct...
Me
Posted By: meh66
Date Posted: December 13, 2004 at 11:34 AM
what bypass module should I use for this vehicle?
MEH66
Posted By: Velocity Motors
Date Posted: December 13, 2004 at 2:13 PM
You have to use a universal type bypass module for this vehicle.
Posted By: hagmanti
Date Posted: December 13, 2004 at 5:04 PM
That is, a 555U or 556U...
Me
Posted By: meh66
Date Posted: December 15, 2004 at 10:24 AM
Thanks everyone for the info, but I still would like to know how I can have the Viper unlock the driver door on first pulse and then the passenger doors on the second pulse. I am not sure since the unlocking/locking function you are only required to tap one wire. I know the viper has this capability and the car has the capability since the factory security system has that feature. Basically I am looking for a driver door unlock wire only. Any suggestions?
MEH66
