Remote Start; What's Best????
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=4512
Printed Date: March 26, 2026 at 4:09 PM
Topic: Remote Start; What's Best????
Posted By: streetrod
Subject: Remote Start; What's Best????
Date Posted: October 15, 2002 at 11:19 PM
Jeff/ Anyone else:
I bought a Viper 600ESP,  and I was wondering what was the cheapest way to install remote start? I've done quite a few alarm installs before, but never a rem. start. I have a 1993 Nissan Sentra, w/Tach M/T.
What's the best deal for someone on a College student budget like myself?
StreetChariot Racing
Posted By: Montrealler
Date Posted: October 16, 2002 at 4:10 AM
You may install it yourself but viper are not the easiest first one kind.
take your time double check evrything and should be ok
make sure you can access programing of your viper unit first (it could have be locked by a bit (ch) writer unit.
If it's ok you may start your installation.Dont forget that nissan have a second start circuit that you should feed with an extra relay there is the wiring diagram.
reading is the key of success so read that chart and the installation manual carefully and do-it yourself!!
       ITEM      |     WIRE COLOR     |POL|       WIRE LOCATION        |
|              12V|white               |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness            |
|   SECOND STARTER|BLACK / YELLOW        |+  |ignition harness            |
|         IGNITION|BLACK/ red           |+  |ignition harness            |
|        ACCESSORY|WHITE/ blue/brown dot|+  |ignition harness            |
|       POWER LOCK|lt. GREEN/ black  *1 |   |at switch in door           |
|     POWER UNLOCK|same wire           |   |                            |
| PARKING LIGHTS +|RED / blue            |   |conn. above fusebox         |
| PARKING LIGHTS -|                    |   |                            |
|       HEADLIGHTS|RED / yel, RED / blue   |+  |light switch-sep. L&R       |
|     DOOR TRIGGER|RED / white    *2     |-  |yel.plug above dr.kick      |
|  TRUNK/HATCH PIN|red                 |-  |sw. or light in trunk       |
|       TACHOMETER|GREEN/ YELLOW,blu/blk|   |coil,instrument panel       |
|       BRAKE WIRE|RED / green           |+  |brake pedal switch          |
|     HORN TRIGGER|GREEN / WHITE         |-  |steering column             |
|           WIPERS|RED / silver          |   |same harness as ign.        |
|  LF WINDOW UP/DN|blue/red, blue/black|   |must run wire to each       |
|  RF WINDOW UP/DN|blue/red, blue/black|   |door to bypass modules      |
|  LR WINDOW UP/DN|                    |   |                            |
|  RR WINDOW UP/DN|                    |   |                            |
Notes:
*1  Ground to unlock, cut to lock.  *2  (2) RED / white wires common at pin in middle of 16 pin plug
Yes I'm Back 2006...
Posted By: Velocity Motors
Date Posted: October 17, 2002 at 5:24 AM
Doing a remote start compared to an alarm is not that much more difficult. Only a couple more wires but programming can be a pain in the @$$. Take your time and solder all connctions. Use the above supplied wiring diagram and use this forum for additional support if you run into problems.
