05 F350, No cold start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=45292
Printed Date: April 18, 2026 at 2:00 AM
Topic: 05 F350, No cold start
Posted By: speedracertjl
Subject: 05 F350, No cold start
Date Posted: December 15, 2004 at 4:14 PM
I have installed an Omega ComfortStart on an '05 F350 diesel..it does NOT have the PATS system...I learned the tach several times using the tach wire in the vehicle by the e-brake...starts fine if you let the truck warm up..but if its cold...it starts and shuts off after a few seconds...does this 3 times like its supposed too..and tachless mode doesn't work either...any ideas? has anyone done a ComfortStart in one of these? other than this "cold start" problem the system is great.any help is greatly appreciated.
Posted By: auex
Date Posted: December 15, 2004 at 4:20 PM
Did you do anything with the wait to start, like a timer?
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: bbeach15
Date Posted: December 15, 2004 at 11:05 PM
if there is a menu for that starter you should turn off engine checking
Date Posted: December 16, 2004 at 4:29 PM
i did a 10 second delay..and there is NO menu for engine checking...any other proven tach wire color and location maybe?
Posted By: snguyen
Date Posted: December 16, 2004 at 5:14 PM
The GREEN / WHITE wire can be found high in the driver kick/driver underdash area. Look for a large harness with a few loose wire taped to it. The loose wire will have a heatshrink on the tips. It seem that the newer models now reads a lower singal than in the past. So you may have to use a tach booster. There is also another place you can grab the tach. That is gray@the PCM under the hood. It is located next to the battery on the driver side. Pull the battery termial and you should see module with three plug. good luck!
Posted By: SAR
Date Posted: December 17, 2004 at 4:34 PM
you'll need a longer glow plug time. i did a 04 f550 and the glowplugs would stay on for 2-3 min. i had to pull the ipc apart and solder on to the actual bulb.
Posted By: daze
Date Posted: December 17, 2004 at 6:55 PM
I had the same problem on an 05 f350 king ranch ! The only thing that worked was time ! I must have spent 20 hours collectivly and the guy was scheduled to come back to take it out and out of no where it just worked.
