Viper 791VX RS green wire, key side?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=45306
Printed Date: April 18, 2026 at 1:19 PM
Topic: Viper 791VX RS green wire, key side?
Posted By: adam.l.walker
Subject: Viper 791VX RS green wire, key side?
Date Posted: December 15, 2004 at 7:11 PM
Can anybody tell me how to hook up the green wire from the RS relay satellite.  It says to hook it to the key side of the starter wire, but I don't know what that means.  My vehicle is a 1998 Ford F-150 (w/out any kind of theft system -- no PATS, no transponder key, etc.).  I hooked the purple wire from the RS relay satellite to the (red / lt. blue) vehicle starter wire under the steering column, but I have no idea what to do with the green one from the RS relay satellite.  Can anybody help me out.  Thanks in advance.
-Adam
Posted By: vlepouce
Date Posted: December 15, 2004 at 8:39 PM
I am by far not an expert.  When I recently did my 97 Blazer, the instructions said to cut the starter wire after positively identifying it.  Purple gets soldered to the starter side and the green gets soldered to the key side.  You end up connecting them throught the remote start relay.  This is for the antigrind and the starter kill.  Hope this helps.
Vic
Posted By: Hymer
Date Posted: December 15, 2004 at 9:06 PM
Yep that will Git r' Done! Just make sure to double check ALL your connections!
good luck...
Posted By: hagmanti
Date Posted: December 16, 2004 at 11:25 AM
The key side is the side closer to the key (pretty obvious), but in cars where that's hard to tell, it's the side that goes to 12V when you crank after cutting the wire (and the car doesn't start).
Me
Date Posted: December 16, 2004 at 12:24 PM
Ok.. thanks for your help everybody.
