ALARM EXPERT PLEASE HELP ME
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=45371
Printed Date: April 19, 2026 at 1:50 AM
Topic: ALARM EXPERT PLEASE HELP ME
Posted By: Skyvan
Subject: ALARM EXPERT PLEASE HELP ME
Date Posted: December 16, 2004 at 7:15 PM
Hello
I try to install the alarm myself this is the first time i do this. I have a alarm with remote starter everything are finish but i'am stuck at this option please look at the picture . i'am too poor to have  scaner so i draw it as much as i can please help me i do not know which wire go with which.. i know GRAY connect to YELLOW but other than that i'am stuck pleaseee help me
thanks you
posted_image
Posted By: auex
Date Posted: December 16, 2004 at 7:25 PM
Wow, your paint skills suck. The gray will go to the ground when armed wire from the alarm, the black will go to a source of true ignition, and the greens go to one end of the cut starter wire. At any rate here is a diagram you need to follow.
posted_image
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: Skyvan
Date Posted: December 16, 2004 at 7:32 PM
Thanks please let me confirm one thing. Yellow go with Gray, Black, White go with bottom GREEN. then Bottom Green go to Ignition.  Then the top Green go to the other end of the cut out ignition is this correct ?
Posted By: auex
Date Posted: December 16, 2004 at 10:31 PM
Your diagram is wrong. One of the green wires goes to one end of the cut starter wire, not ignition, the other green goes to the other end of the cut starter wire. Hook the grey wire up to the starter kill negative 500ma wire (what ever color that wire is of the alarm). The black wire (according to your diagram) in the relay diagram would go to ign, a wire that has power in run and start only or the white "key on" signal +12V.
