04 suburban remote start problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=45496
Printed Date: May 05, 2026 at 9:53 AM
Topic: 04 suburban remote start problem
Posted By: chevyjr73
Subject: 04 suburban remote start problem
Date Posted: December 18, 2004 at 10:15 PM
i installed a remote starter on a 04 suburban. it will crank over with the remote starter but the engine will not run. i installed the passlock 2 bypass system. im pretty sure i wired it correctly. could the wrong wire for the tach signal being hooked up cause this symptom? what effect exactly does the tach wire have on the remote start system? any help would be greatly appreciated.
Posted By: KarTuneMan
Date Posted: December 19, 2004 at 2:41 AM
12volts
 red & RED / white
 ignition harness
Starter yellow  +  ignition harness
Second Starter N/A
Ignition pink  +  ignition harness
Second Ignition white  +  ignition harness
Third Ignition N/A
Accessory orange  +  ignition harness
Second Accessory brown  +  ignition harness
Keysense lt. green  -  ignition harness
Power Lock use Directed module 456G
Power Unlock see power lock
Lock Motor gray    driver door module in door
Unlock Motor tan    driver door module in door
Parking Lights+ brown  +  driver kick panel
Parking Lights- gray/black  -  switch or BCM, brown
Date Posted: December 19, 2004 at 2:43 AM
Door Triggersee notes - see notes
The BCM (Body Control Module) is under the driver side dash. It has 6 plugs in it, the purple plug is on the back.","CHEVROLET, SUBURBAN, 2004, Door Trigger");' href="https://www.directechs.com/directwire/wire_body.asp?action=select&yr=5632&product=Remote Start#">posted_image
Dome Supervisiongray/black + BCM, black plug, pin E posted_image
Trunk/Hatch Pinpink/black - BCM, purple plug, pin A1 posted_image
Hood PinN/A
Trunk/Hatch ReleaseN/A
Power Sliding DoorN/A
Factory Alarm Armarms with lock
Factory Alarm Disarmlt. green - driver door module in door
Disarm No Unlocksee factory alarm disarm
Tachometerwhite ac instrument cluster, pin A5 or PCM posted_image
Wait to startN/A
Brake Wirewhite + brake pedal switch
Parking Brakelt. blue - switch or BCM, lt. blu plug, pin A7 posted_image
Horn TriggerBLACK / YELLOW to black - column or BCM, gray plug, pin B9 posted_image
Memory Seat 1red + driver door module in door
Memory Seat 2pink + driver door module in door
Memory Seat 3N/A +
Immobilizer Bypass Module
posted_image
MAKE : CHEVROLET | MODEL : SUBURBAN | YEAR : 2004
* The logo is registered trade mark of Chevrolet Corporate.
Copyright © 2000-2001 Directed Electronics, Inc. All Rights Reserved. Revised: 11 January 2001
Date Posted: December 19, 2004 at 2:46 AM
maybe also passlock III
Posted By: mobileworks
Date Posted: December 19, 2004 at 3:35 PM
I would say that depending on the bypass that you used, its either hooked up wrong or not programmed properly.
Or the Starter kill anti gring wiring is backwards.....
what kind of components brand and models did you install
Date Posted: December 19, 2004 at 4:37 PM
i installed a python remote start/alarm and a dei 555L bypass module. sure every wire is right except i wasn't quite sure on the tach wire. i had a couple of diagrams that said you could use a wire from the injectors that wasn't pink or one that was a different color but both the injector wires measure 12 volts or more any time the ignition is on even if the vehicle isn't running. isn't the tach wire only supposed to send a signal when the engines running? also isn't it supposed to be ac voltage? i think this may be the problem but not quite sure. would having the wrong tach wire cause this problem? (engine cranks but won't start).
Posted By: vinman75
Date Posted: December 20, 2004 at 3:55 PM
It sounds to me like the bypass isn't right. The yellow from the bypass should be to the cut keyside of the yellow resistance wire in the truck, the black / YELLOW from the bypass should be to the cut car side of the yellow resistance wire. The black ground reference wire should be tapped to the ground reference wire in the truck, most likely orange or black. I take the steering column shroud completely off to conect these wires right under the ignition switch. remember to solder these wires so they see a true resistance. After checking to make sure that those three wires are correct make sure you are getting a good constant 12volts and good ignition to the bypass module. After that is done check to make sure that the blue status output from the alarm is connected to the bypass module. Then insert a key in to the ignition and start the truck once the factory security light goes out the key resistance is learned turn the truck off and try to remote start.
Date Posted: December 21, 2004 at 7:49 PM
your tach wire for this is WHITE ...in the underhood pcm next to the battery
