trouble installing keyless entry kit
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=45500
Printed Date: May 05, 2026 at 12:40 PM
Topic: trouble installing keyless entry kit
Posted By: hititram
Subject: trouble installing keyless entry kit
Date Posted: December 19, 2004 at 12:15 AM
Im having trouble installing this Omega REC43 keyless entry kit. I have made a website that has pictures and all the paper work on the install. It is putting in a keyless entry kit in a 2002 malibu. The malibu has automatic locks but my sister wants the remote now. Well it is a single wire resistor door lock system and i've never touched one of those before. The kit I bought had an add on unit that I need to chage the polarity or some stuff like that.  Please help me out. This is a xmas gift!
https://www.geocities.com/bahrhopper/malibu.htm
Theres the link to the site with pics and more description. Thank you in advance!
Posted By: KarTuneMan
Date Posted: December 19, 2004 at 2:05 AM
1.5k resistor ground will un lock........solid ground will unlock.
White wire purple connector, in the drivers kick.....
Your site tells me, or shows me instructions for an Impalla, not a maibu.    If its a malibu, lock is 465 ohms and unlock is solid ground.
Posted By: hititram
Date Posted: December 19, 2004 at 10:56 AM
Ok you are correct it is an Impalla. Sorry.  Now 1.5k resistor ground will unlock? Is that the adjusting feature on the DLR-U single wire resistor page they are talking about? Also the white wire you say is in the purple connector, what do I connect to that? Do you know what wires on the actual unit ground it and which one I am suspossed to supply a 12v to.  If you have time can you call me about this? I got some questions. I appreciate your help.  785-969-6974
