98 nissan maxima clutch bypass
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=45511
Printed Date: May 05, 2026 at 11:28 PM
Topic: 98 nissan maxima clutch bypass
Posted By: audiopete
Subject: 98 nissan maxima clutch bypass
Date Posted: December 19, 2004 at 1:16 PM
need to know if i have postive or negative  i do have cruise control
Posted By: profuse007
Date Posted: December 19, 2004 at 5:46 PM
negative trigger. use the switch b4 the clutch, which is the clutch switch. the switch after the clutch is for cruise control.
Houston,TX
Date Posted: December 19, 2004 at 9:28 PM
thanks alot profuse will try
