1994 honda accord, remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=45640
Printed Date: May 07, 2026 at 6:10 PM
Topic: 1994 honda accord, remote start
Posted By: 01blkgts
Subject: 1994 honda accord, remote start
Date Posted: December 20, 2004 at 7:30 PM
can anyone tell me where i can find the door lock/unlock wires  to install a keyless entry...
thanks
Posted By: ksutton
Date Posted: December 20, 2004 at 7:53 PM
2 pin plug above fuse box
Posted By: Autoobsession
Date Posted: December 20, 2004 at 8:16 PM
It is a green plug which is usually hanging to the left of the steering column behind the metal support beam.
Posted By: 01blkgts
Date Posted: December 20, 2004 at 8:28 PM
the 2 pin plug above the fuse box....
i see the 2 pin plug....but it doesnt  look  like its connected to anything on the end of it....is that the wires?
thanks
Posted By: 01blkgts
Date Posted: December 20, 2004 at 8:31 PM
hi, i have a DEI remote start and keyless entry system..model #  265B
is it possible to just do the remote start and not the keyless entry? this is for a 94 accord
if so, how do you do it?
thanks
Posted By: ksutton
Date Posted: December 20, 2004 at 9:40 PM
test them with your meter
Posted By: Hymer
Date Posted: December 20, 2004 at 9:41 PM
Just don't hook up the lock/unlock feature..
Posted By: mykicks007
Date Posted: December 21, 2004 at 6:34 AM
or go buy the 165b model, it is just remote start and is cheaper
Posted By: 01blkgts
Date Posted: December 21, 2004 at 8:58 AM
well i already bought the thing, and am working on the keyless feature....but can't seem to find the wires too well....so if i just want the remote start....what wires do i connect?
Date Posted: December 21, 2004 at 9:45 AM
what car, year, make, model ? does it have power locks ?
Posted By: 01blkgts
Date Posted: December 21, 2004 at 12:06 PM
its for a 94 accord EX 4 door
it does have power everything
Date Posted: December 21, 2004 at 3:14 PM
this link should have all the wires you need and where to look for them, take your time, it is worth the extra effort to hook up keyless entry and do it right, read your manual closely and it should tell you what color wire to hook into from this diagram
https://www.the12volt.com/request/94accord.asp
Posted By: 01blkgts
Date Posted: January 02, 2005 at 11:08 PM
i installed a boa remote start on a 94 accord ex...everything works fine, but once in a while, after i start it with the remote, it would sometimes shut off by itself...and start again...it doesnt make that starter grind noise....(it did before i connected the tach wire though)...
amyone know what the problem is?
thanks
