’00 Chrysler 300M alarm/remote start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=45644
Printed Date: May 07, 2026 at 1:35 PM
Topic: ’00 Chrysler 300M alarm/remote start
Posted By: antol11
Subject: ’00 Chrysler 300M alarm/remote start
Date Posted: December 20, 2004 at 8:23 PM
Hi, I am currently installing an alarm/rs in a 2000 Chrysler 300M. Everything is going smoothly for the most part but I don't know how/where I can route wires through the firewall? If anyone has experience with the 300M and would like to enlighten me with the best (or in other words easiest) location where I could route wires throught the firewall I would greatly appreciate it. Please don't tell me that I am going to have to remove the seating and pull pack the carpeting and drill. Thanks in advance, Bogdan
Posted By: extreme1
Date Posted: December 20, 2004 at 8:52 PM
through the grommet for the shifter cable, it's above the gas pedal.
------------- Shaughn Murley
Visions Electronics
Red Deer, Alberta
Posted By: Ravendarat
Date Posted: December 21, 2004 at 1:44 AM
You can also go through the gromet that the hood release cable travels through.
------------- double-secret reverse-osmosis speaker-cone-induced high-level interference distortion, Its a killer
Posted By: antol11
Date Posted: December 21, 2004 at 9:47 AM
Thanks guys, I'll look at both locations and go with what works for me. Thanks again, Bogdan
Posted By: antol11
Date Posted: December 22, 2004 at 2:20 PM
Just wanted to say thanks again, it was as easy as pie once I knew where to look! Bogdan
Posted By: antol11
Date Posted: December 22, 2004 at 2:25 PM
Hi, The wiring info for the 2000 Chrysler 300M says the tach wire is at the "coil" and is tan/white. My problem is I don't know where the "coil" is. Also when they say coil do they mean distributor? I found a tan/white wire in one of the looms but it reads .7VAC and doesn't fluctuate when I hit the gas. Can anyone describe the location of the tach wire with more detail? Thanks, Bogdan
Posted By: extreme1
Date Posted: December 22, 2004 at 5:00 PM
tan white at PCM behind drivers headlight
Visions Electronics
Red Deer, Alberta
