tach wire in 1997 montero sport
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=4575
Printed Date: March 25, 2026 at 1:31 AM
Topic: tach wire in 1997 montero sport
Posted By: brianh
Subject: tach wire in 1997 montero sport
Date Posted: October 17, 2002 at 7:05 PM
I have a remote starter on my Montero sport. I hooked it up in tachless mode and it has been doing fine until recently. Somtimes it wont start on the first time . I think I know where the tach wire is (under the hood). There is a blue connector with one white wire in it .(looks like a test connector) on the driver side fire wall. I tested it with a meter set on ac volts and it would rise and fall from 1 to 6 volts. Based on engine speed. Is this the right wire? Any info would be great. Thanks in advance. Brianh
Posted By: Velocity Motors
Date Posted: October 17, 2002 at 8:47 PM
Yes, this is the right wire. Attach to the tach input wire of the RS unit and make sure that if there are any pin switches to be turned ON for the system to register a tach mode...... that you do it. Otherwise it will not work.
------------- Jeff
Posted By: brianh
Date Posted: October 18, 2002 at 7:57 AM
Thanks for the information Jeff. I thought that I had the right wire but I wanted to be sure. I'll hook it up this afternoon and see if it helps. Thanks again. Brianh
