door lock relays
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=4590
Printed Date: March 24, 2026 at 5:57 PM
Topic: door lock relays
Posted By: rayjenn
Subject: door lock relays
Date Posted: October 17, 2002 at 9:52 PM
I have a 1998 chev half ton without keyless entry.Could someone tell me how the relays should be wired in, and is this a five wire system. Thanks very much in advance.
rayjenn
Posted By: SOUND PRESSURE
Date Posted: October 17, 2002 at 10:22 PM
https://www.the12volt.com/installbay/detail.asp?info=alarm&year=1998&make=Chevrolet&model=C/K%20Pickup&ID=17378&type=Alarm
On the information provided here it says that if you do not have the keyless entry, it is a five wire alternating. If so follow the diagram below.
https://www.the12volt.com/doorlocks/page3.asp#5w
Hope this helps.
Sound Pressure
