2005 Mustang remote start info?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=45927
Printed Date: April 19, 2026 at 6:17 AM
Topic: 2005 Mustang remote start info?
Posted By: floaterr
Subject: 2005 Mustang remote start info?
Date Posted: December 24, 2004 at 11:23 AM
ANyone have any info on remote start wiring on the 2005 Mustang yet?
Thanks in advance
Posted By: KarTuneMan
Date Posted: December 24, 2004 at 1:37 PM
12volts
 lt. GREEN/ purple (20A)
 ignition harness
Starter dk. green  +  ignition harness
Second Starter N/A
Ignition WHITE/ yellow  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory BLACK/ pink  +  ignition harness
Second Accessory N/A
Keysense lt. GREEN/ purple  +  ignition harness
Power Lock WHITE/ purple  -  DKP or SJB, blk 26 pin plug, pin 3
Power Unlock dk. blue/lt. green  -  DKP or SJB, blk 26 pin plug, pin 1
Lock Motor RED / orange  5wi DKP or SJB, blk 5 pin plug, pin 3
Unlock Motor yellow  5wi DKP or SJB, blk 5 pin plug, pin 1
Parking Lights+ SJB ctrls each light separate
Date Posted: December 24, 2004 at 1:40 PM
Door Triggeruse dome supervision wire
Dome Supervisionlt. GREEN/ YELLOW - SJB, gry 26 pin plug, pin 25
Also found in the passenger side A pillar.","FORD, MUSTANG, 2005, Dome Supervision");' href="https://www.directechs.com/directwire/wire_body.asp#">posted_image
Trunk/Hatch PinWHITE/ yellow + lt. or SJB, blk 26 pin plug, pin 15 posted_image
Hood PinPURPLE / orange - pin or SJB, blk 52 pin plug, pin 15 posted_image
Trunk/Hatch ReleaseWHITE/ purple - PKP or SJB, blk 52 pin plug, pin 13 posted_image
Power Sliding DoorN/A
Factory Alarm Armlt. blue/pink - DKP or SJB, blk 26 pin plug, pin 18 posted_image
Factory Alarm Disarmlt. blue/black - DKP or SJB, blk 26 pin plug, pin 9 posted_image
Disarm No Unlocksee factory alarm disarm
TachometerNOT red ac any ignition coil or fuel injector
Wait to startN/A
Brake Wirelt. green + sw. or SJB, gry 36 pin plug, pin 16 posted_image
Parking BrakeRED / yellow - sw. or SJB, blk 52 pin plug, pin 50 posted_image
Horn Triggerdk. blue - col. or SJB, blu 52 pin plug, pin 39 posted_image
Date Posted: December 24, 2004 at 1:42 PM
  SLB   smart junction box...in the pass kick
Posted By: floaterr
Date Posted: December 25, 2004 at 2:09 AM
Thanks!
I was installing some stereo equip and was wondering for future reference.
If you have the time..
The wires from the ign switch seemed really small guage, I really didn't have time to peel everything back though. Are they just really small or did I just not investigate fully?
Thanks for your time.
Posted By: swamprat323
Date Posted: December 25, 2004 at 9:03 AM
Why when i click on the notes, the car it say is an acura CL 2003
Posted By: floaterr
Date Posted: December 25, 2004 at 10:44 AM
I notived that too. It says to install a 555u for immobilizer. I think it was a generic link to the proper bypass kit
Posted By: auex
Date Posted: December 25, 2004 at 2:05 PM
05 Mustang Remote start/alarm info
05 Mustang Audio info
05 Mustang Accessory info
$50 says this will be asked 100 times next year and not a single one of the people who asks for this info will have used the search button.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
