Car won’t remote start?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=45935
Printed Date: April 19, 2026 at 1:26 AM
Topic: Car won’t remote start?
Posted By: Jack Daniels
Subject: Car won’t remote start?
Date Posted: December 24, 2004 at 2:47 PM
I just wired up my 98 Blazer, with a Valet Remote Start system.  I have done a couple of systems before, but this one isn't acting like the others.  When I push the remote start button twice, the module doesn't click or anything, normally it does, but no remote start, any ideas?
JD
Posted By: mo12v
Date Posted: December 24, 2004 at 3:23 PM
Are remotes programmed??
Would want to check Negative side of Brake Switch WHITE Wire for proper connection and Ground
If you installed Hood Pin ....Check it also
MO
Posted By: godsegoizhuge
Date Posted: December 24, 2004 at 10:12 PM
could also check the gray/black wire that's supposed to goto the toggle switch to see if that's seeing a ground. If it isn't then that will also cause the remote start not to function correctly.
