autopage RST 2050 KE
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=45939
Printed Date: April 18, 2026 at 9:44 PM
Topic: autopage RST 2050 KE
Posted By: savary24
Subject: autopage RST 2050 KE
Date Posted: December 24, 2004 at 4:13 PM
Hello, can anyone give me information on installing the Autopage RST 2050 KE. I am installing in a 2003 Monte Carlo, a 1999 Dodge Ram and a 1992 Dodge Spirit. Any information on the vehicles or the starter will be helpful. Thanks
Posted By: KarTuneMan
Date Posted: December 24, 2004 at 4:33 PM
DIRECTWIRE™ WIRING INFORMATION - DODGE / RAM PICKUP / 1999 / Remote Start
[PRINT THIS PAGE]
12volts red and pink/black   +  ignition harness
Starter yellow   +  ignition harness
Second Starter
Ignition dk. blue   +  ignition harness
Second Ignition
Third Ignition
Accessory BLACK/ orange  +  ignition harness
Second Accessory BLACK/ white  +  ignition harness
Keysense
Power Lock ORANGE / purple  5wi driver door harness
Notes: Keyless models use positive trigger for lock, and 5-wire for unlock. Can also find wires at the central timer module to the right side of the steering column, lock is ORANGE / green, unlock is pink/green.
Power Unlock pink/purple  5wi driver door harness
Lock Motor
Unlock Motor
Parking Lights+ BLACK / YELLOW    drivers kick panel
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger yellow   -  drivers kick panel
Notes: To avoid dome delay, use tan for the drivers door and BLACK/ lt. blue for the passenger door. Both wires are located at the central timer module to the right side of the steering column. Use both wires and diode isolate each.
Dome Supervision
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release
Power Sliding Door
Factory Alarm Arm arms with lock
Notes: Must see a ground on the tan drivers door trigger wire while locking to arm the factory alarm. This only works if the vehicle does not have delayed domelight.
Factory Alarm Disarm lt. GREEN/ orange   -  harness from door
Disarm No Unlock
Tachometer BLACK/ gray    ignition coil
Notes: Diesel tach wire is gray/black. The wire is located on the center of the firewall. There are two black plugs, the wire is in the top plug without the white insert. The tach wire can also be found at the ECM on the passenger side firewall in connector C-1, pin 8.
Wait to start ORANGE / black  -  center of firewall, black plug
Notes: See DirectFax document 1090.
If using the ORANGE / black for wait to start causes a shifting or cruise control problem then use a pulse timer relay instead. Refer to DirectFax 1091 for wiring information.
Brake Wire WHITE/ tan   +  at brake pedal switch
Parking Brake
Horn Trigger BLACK/ red   -  steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
posted_image
Immobilizer Bypass Module:Required: NoType: N/APart #: N/A
Notes: N/A
posted_image
posted_image
