door locks after remote started
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=45972
Printed Date: April 18, 2026 at 9:44 PM
Topic: door locks after remote started
Posted By: wblakes
Subject: door locks after remote started
Date Posted: December 25, 2004 at 9:31 AM
i'm installing a viper 791 into a 1997 lexus es 300. to disarm the factory alarm you need to unlock doors. how do i relock the doors after the car is remote started. which wire do i use? thanks
Posted By: swamprat323
Date Posted: December 25, 2004 at 9:43 AM
just hit lock after you RS. What about using the disarm defeat.
Posted By: wblakes
Date Posted: December 25, 2004 at 9:45 AM
i want it to relock automaticly. i'm still new to this i don't even know what disarm defeat is.
Posted By: slicksam
Date Posted: December 25, 2004 at 10:05 AM
hey wblakes,
try this, sit in the car arm the ORIGINAL alarm system....wait 10 to 15 sec til the system is fully armed......then try starting the car by KEY. See if the alarm goes off....if it does....your remote starter should have the option of programming for unlock before start and lock after start and lock on shutdown
If it doesn't go off.....remove the option to unlock before start and leave everything as is.
as for this wire your looking for.....the door locks wires which you have connected already......the features for the doorlocks on the 791 can be changed to whatever you like.
I tried looking for your installation guide on your unit, but I couldn't find it
Testing is the key
Posted By: wblakes
Date Posted: December 25, 2004 at 10:09 AM
i know that the compustar alarms have the option of unlock before start and relock after start. the vipers do not have this option. i can started the car but just don't want the car to be unlock while it's running for the 12 minutes. will it work if i use the starter output wire and pulse the lock wire for it to lock the doors after it started?
Date Posted: December 25, 2004 at 10:12 AM
Also may could use your rear defforger set it to pulse this turns on 10 secs after the RS is on. Use relay though. Thsi may not be the best way to do it, just a thought. Never came across this before.
Posted By: liinstaller
Date Posted: December 25, 2004 at 5:42 PM
just use the ground out while running to the key sense wire and you will not have to unlock then relock the doors.
Posted By: mobileworks
Date Posted: December 25, 2004 at 7:03 PM
I would suggest using the key sense wire as well.
Posted By: wblakes
Date Posted: December 25, 2004 at 10:34 PM
anyone know what color is the keysense wire for this car?
Posted By: Velocity Motors
Date Posted: December 25, 2004 at 10:51 PM
RED / BLUE (-) at the ignition switch by the steering column.
Posted By: benz300
Date Posted: January 09, 2005 at 8:34 PM
can someone kindly tell me what the key sense wire is for a 01 lexus lx470. thanks.
