451M, ground on red wire
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=46013
Printed Date: April 18, 2026 at 10:56 AM
Topic: 451M, ground on red wire
Posted By: hagmanti
Subject: 451M, ground on red wire
Date Posted: December 25, 2004 at 8:10 PM
Does anyone know what happens w/ a 451M when you put ground on the red wire and 12V on the green (and/or blue) wire? Is it a straight short-circuit? Do relays click?
I'm assuming it'll short-circuit, so if you're testing this out, use a fuse...
Hoping someone has one handy, 'cause I don't,
   Me
Posted By: profuse007
Date Posted: December 25, 2004 at 8:33 PM
why would you ground the red wire when it has 12volt (+) constant?
Houston,TX
Posted By: hagmanti
Date Posted: December 25, 2004 at 8:36 PM
Because I have a lot of 451Ms, a shortage of normal relays, and am trying to get creative. :)
Me
Date Posted: December 25, 2004 at 8:39 PM
you sure have a lot of time on ur hand, hangman....
Me
Houston,TX
Posted By: auex
Date Posted: December 26, 2004 at 12:01 PM
Just think of the red wire as pin 86 of both internal relays.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
