Compustar cm 4200 no start
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=46046
Printed Date: April 14, 2026 at 9:05 PM
Topic: Compustar cm 4200 no start
Posted By: Neolax1981
Subject: Compustar cm 4200 no start
Date Posted: December 26, 2004 at 1:10 PM
I installed a Compustar CM 4200 in my 2001 GMC Sierra. I also have installed a DEI 555L passlock module. I thought I had everything right but when i try starting the truck with the remote start nothing happens. Any ideas? Thanks in advance.
Posted By: profuse007
Date Posted: December 26, 2004 at 1:35 PM
-make sure all shutdown triggers are appropriately installed. i.e. hood, neutral, brake...
-also, if ur GMC is manual, make its in a ready mode b4 remote start. if ur GMC is auto, cut the loop inside the brain and you DO NOT need to hook up the e-brake wire.
------------- Houston,TX
Date Posted: December 26, 2004 at 2:23 PM
First thanks for getting back so quickly-- The hood switch is in right(and the hood is closed), It's an automatic and the loop is cut. I found the tach wire per the Compustar instructions but when i have the truck running and push the tach learn button nothing happens. The instructions said the tach wire when running would read 2-8 volts AC and it does. When I try to remote start nothing happens. I even tried leaving the key in the ignition to see if the DEI bypass was defective or hooked up wrong. The only idea that i have the yellow lead off the compustar feeds a relay. That relay has a yellow, a yellow/black, a purple, and a red. The instructions said nothing about these. Any ideas? Once again thanks in advance.
Posted By: Velocity Motors
Date Posted: December 26, 2004 at 5:18 PM
First off, did you program the remote control ? NExt if the 1WAMS did not give you a single flash back with the parking lights after pressing the tach learn button, you do not have the proper wire for the tach signal or you used the wrong wire on the harness. The tach wire is the YELLOW/BLACK wire and the tach wire on the truck is any injector or it's the WHITE wire at the ECM located near the battery, down low, between the fender and the fan under the black plastic cover. On the 4.3L, the tach wire is at pin 20 in the connector labeled red, and VSS wire is at pin 3 in the connector labeled black. On the 4.8L, 5.3L, and 6.0L, the tach wire is located at pin 10 in the red connector, and VSS wire is located in pin 50 of the red connector. The Yellow wire off the relay goes to the starter side of the cut starter wire ont he truck. The YELLOW/BLACK wire goes to the switch side of the cut starter wire. The PURPLE wire goes to the purple wire off the CN2 harness as this is your anti grind/ starter kill wire. If you did not hook up the yellow wire off the CN1 harness your truck will not start or even attempt to start. ------------- Jeff
Date Posted: December 26, 2004 at 9:04 PM
There weren't any directions that I saw about programing the remotes. So I never did, also I don't know how. For the tach wire I hooked up the white behind the gauges. It tested out fine so I think that it's right. Also if I push the tach learning button when the truck is not running it flashes the light 3 times then a short pause then it flashes 2 more times. Does this mean anything?
Posted By: metaverse
Date Posted: December 26, 2004 at 9:54 PM
Your remotes will never work without programming. two things you have to do on compustar before all systems are go is to program the remote, and go tell what mode the unit has to be in..voltage/tach etc. I had to do this on a 1WFM-AS which had an older 3000 brain compared to the latest CM 4200 which you are installing. I bet your remote is not even responding to basic lock/unlock. reset the alarm brain, program the remotes and then try it again..
Date Posted: December 26, 2004 at 10:18 PM
Thats what I heard, that I need to program them, but how do I program the remotes? I set the switches and cut the jumper in the "brain" but I don't know how to program the remotes.
Date Posted: December 26, 2004 at 10:46 PM
To program the remote control you have to toggle the ignition switch to the ON postion and back to the OFF position 5 times within 5 seconds really fast. The parking lights will flash back once and when it does, press the LOCK button on the remote control and if you are programming both remote's, press the lock button on the 2nd remote within 2 seconds of pressing the lock on the 1st remote. After about 5 seonds the lights will flash back at you to confirm the remote code was learned. The tach program button will do this all the time regardless of if the vehicle is running or not. If you have the proper tach wire, the lights will flash back ONLY ONCE. ------------- Jeff
