varad hyper led's
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=4605
Printed Date: March 24, 2026 at 8:10 AM
Topic: varad hyper led's
Posted By: ShaunD912
Subject: varad hyper led's
Date Posted: October 18, 2002 at 10:40 AM
I recently purchased 5 blue varad led's. I am planning on putting them in the a/c vents in a 99 chevy silverado. I plan to have them flash with the alarm led (which i will replace with a blue led), and the one's in the vents stay on when the parking lights are on. I have a couple of questions about this setup. Let me explain how I was going to do this and see if it makes sense. I was going to cut the wires for the alarm led and use them to power a relay to control all 5 led's. The positive wires of the 4 that are in the ac vents will also be run to pin 87a on another relay. I will then wire the 4 leds to pin 30 of this relay. I was going to use the parking light wire to trigger the second relay and send 12v to these 4 leds. Does it seem like this will work without any problems. One more thing. Will hot and cold air cause problems for these leds in the future? I think that's it. Thanks
Date Posted: October 18, 2002 at 10:41 AM
Let me clarify in case this is confusing. All 5 leds will flash for the alarm. When the parking lights are on the 4 in the a/c vents will stay on and the 1 that replaced the alarm led will still flash for the alarm.
