remote start 2005 deisel ford f 250
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=46055
Printed Date: April 14, 2026 at 12:04 PM
Topic: remote start 2005 deisel ford f 250
Posted By: hafr
Subject: remote start 2005 deisel ford f 250
Date Posted: December 26, 2004 at 3:39 PM
i got the truck almost all done on christmas eve. all but 2 things.
The wait to  start wire
and the wake up wire for the vsc(vehicle security controll) for the door unlock after the truck sits a while (similar to the 2003 2004 explorers.
i am installing a rs900 crimestopper unit on a 2005 turbo deisel f250 pickup. I am using a new transmitter with the door locks.
Rich Hawthorne
Hands-Free installations
"don't talk with your hands full"
516-no-hands
Posted By: secureauto
Date Posted: December 26, 2004 at 4:27 PM
I couldn't find wait to start info, but here'e a link to DEI timer module (528t):
Wait to start using 528T
Here's a link for the VSM wakeup:
VSM Wake up
ASE Certified
Posted By: KarTuneMan
Date Posted: December 29, 2004 at 1:31 PM
The astrochart shows for 2004 anyhows its a green and white wire at the glow plug relay on the firewall under th hood pass side.  Little silver box with a green plug.  Its POS. I dont know if its the same as 05.
Break the drivers door pin wire with a relay and "pulse it" before unlock and "pulse it" after lock or remote start. That will wake up the bcm, and shut the radio off  after run time
Posted By: extreme1
Date Posted: December 29, 2004 at 6:33 PM
the 04/05 ford superduty's are negative trigger door wires now. you have to send a negative pulse.
fyi, there's about a 5% chance it has the GEM sleep mode, as everyone I've done doesn't have that feature.
there has been no wait to start wire since 2001 on thos trucks.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
Posted By: hafr
Date Posted: December 29, 2004 at 6:43 PM
  Can i Make a latching relay for 30 seconds on the wait wire from the remote start?
that should work, shouldn't it
thanks
Rich Hawthorne
516-no-hands
Posted By: brianh
Date Posted: December 30, 2004 at 3:59 PM
The unit that I install on these trucks has a built in glow plug timer and it works great at 20 seconds. If your unit does not have this feature use a timer relay.
Brian
owner/installer
Sight & Sound Car Stereo
"all electronic equipment runs off of smoke, once you let it out, it stops working"
