Astrostart installation guide 4 02 cavi
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=46072
Printed Date: April 13, 2026 at 5:37 PM
Topic: Astrostart installation guide 4 02 cavi
Posted By: 02cavy
Subject: Astrostart installation guide 4 02 cavi
Date Posted: December 26, 2004 at 8:31 PM
does anyone have or can tell me where to get an installation guide 4 installing a astro start #1105 EC with manual interface P/N#310-067-500 and passkey interface? I have already installed this into my cavi but am getting dianostic code #6 (manual interface sequence) Starter will not take over on continious mode and displays  code 6 i am a beginner installer and a "guide for dummies" would be great
Posted By: 02cavy
Date Posted: December 26, 2004 at 10:51 PM
 I have officially narrowed it down to 2 problems that I have improper tachometer wire (any help would be great) any improper manual interface wiring if anyone have a guide 4 dummies on these two installs thanx.
Posted By: KarTuneMan
Date Posted: December 27, 2004 at 12:14 AM
Astrochart says the tach is white.....@ the Ign. module on the end of the valve cover and camshaft.
Its got 6 wires comminout of it.  Make sure you have your door pins wired up correctly
Date Posted: December 27, 2004 at 12:18 AM
How and where did you buy this astro unit?
These peoplepshould offer some kind of help to you?  If they are an authorized dealer.
This is where re-selling product can be a pain in the butt
Posted By: 02cavy
Date Posted: December 27, 2004 at 10:06 AM
i work in an automotive shop and bought it through one of our suppliers. At the end of my valve cover on the drivers side the is a coil pack with two plugs, one has three wires(white,pink and black) second plug has black and pink wires thought that i could do the install myself. have done a few older vechicles but nothing this new or involved. The car will start under automatic transmission mode but the starter does not stop and i have to hold the clutch in to start. Pretty sure that I have the passlockIII interface in properly. Should I b making my starter connection on the engine side of my clutch saftey switch or in the ignition harness by the column? like i said done older vechicles but never a manual and i think that my manual interface is giving me the most problems kinda funny that the interface with only 3 wires is giving me this much problems. Any help would b great!!!!!
Posted By: 02cavy
Date Posted: December 27, 2004 at 10:08 AM
i work in an automotive shop and bought it through one of our suppliers. At the end of my valve cover on the drivers side the is a coil pack with two plugs, one has three wires(white,pink and black) second plug has black and pink wires thought that i could do the install myself. have done a few older vechicles but nothing this new or involved. The car will start under automatic transmission mode but the starter does not stop and i have to hold the clutch in to start. Pretty sure that I have the passlockIII interface in properly. Should I b making my starter connection on the engine side of my clutch saftey switch or in the ignition harness by the column? like i said done older vechicles but never a manual and i think that my manual interface is giving me the most problems kinda funny that the interface with only 3 wires is giving me this much problems. Any help would b great!!!!! The starter is running because of no tach signal right or have I done something else wrong.
