03 Civic SI clutch Bypass
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=46099
Printed Date: April 13, 2026 at 4:20 AM
Topic: 03 Civic SI clutch Bypass
Posted By: Autoobsession
Subject: 03 Civic SI clutch Bypass
Date Posted: December 27, 2004 at 8:57 AM
Anyone know how to bypass the clutch to install a remote start in this car?
Posted By: Velocity Motors
Date Posted: December 27, 2004 at 7:39 PM
Light Green wire (-) at the clutch . It's in a 2 pin molex connector at the clutch arm beside a Black wire. Use your status output wire ( ground when running ) to activate this wire.
Posted By: Sierra2700
Date Posted: February 23, 2005 at 10:43 PM
Is this all you do to bypass a clutch with a compustar? Just use the status output wire and connect it to the wire on the clutch? Or do you need a relay or anything else? Thanks velocity.
Date Posted: February 24, 2005 at 1:08 PM
Velocity do you have to use a relay such as the one on your website (NEGATIVE CLUTCH BYPASS Circuit) Or Can you simply take the ground out while running wire and hook it up to the clutch wire?
Date Posted: February 24, 2005 at 1:23 PM
I just used the BLACK status wire from the Compustar to bypass the Civic's that I installed into.
Posted By: soundwaves
Date Posted: February 24, 2005 at 1:29 PM
Use a relay!! .....even if the output on the compustar was strong enough you'll just burn out the output on the unit eventually.
Date Posted: February 24, 2005 at 3:27 PM
Have yet to see a customer come back to me with the units that I have installed the way I described above complaining that the remote start doesn't work anymore.
