hooking up a carbine alarm to a 95 F-150
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=4635
Printed Date: March 23, 2026 at 8:52 PM
Topic: hooking up a carbine alarm to a 95 F-150
Posted By: John H
Subject: hooking up a carbine alarm to a 95 F-150
Date Posted: October 19, 2002 at 10:30 PM
I have a carbine alarm I would like to hook up to a 95 F-150,I don't have the manual that tells you what the wires are for,and thats what I need help with.I've installed many sound systems,and I'm a certified electronics technician so I'm not afraid to do this. I have power locks in the F-150,I didn't have them in the ranger that the alarm was installed in before. Other than that it is a basic alarm with no remote start function. Any help would be great,
                Thanks, John H
Posted By: securinu
Date Posted: October 20, 2002 at 5:07 AM
what model carbine unit do you have???
Posted By: John H
Date Posted: November 06, 2002 at 7:12 PM
The alarm is a plus 3000,does anyone know what all these wires are for? I need to get it hooked up.
Thanks,
       John H
Posted By: securinu
Date Posted: November 06, 2002 at 7:26 PM
you should have 2 harness's i 3 wire on a 5 pin plug and a10 pin harness.
3 wire harness=
red      =  12v constant
yellow  = 12v switched
black     =  ground
10 pin harness=
pink  = input for park lights (ford is positive so this wire to 12v constant)
RED / white   =output to park lights
purple   = positive door trigger
brown   = sirne output  +   ( this wire to red wire of siren or brown if you have a carbine siren)
blue = instant negative trigger for hood or camper shell door if you do one or the other
all other wires wont be needed
