97 Bonneville SSEI, astrostart 2205u,tach
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=46366
Printed Date: April 12, 2026 at 4:11 AM
Topic: 97 Bonneville SSEI, astrostart 2205u,tach
Posted By: sonomazr2
Subject: 97 Bonneville SSEI, astrostart 2205u,tach
Date Posted: December 30, 2004 at 8:22 AM
Starter will not disengage.  Did the manual setting of 1,7,8 on.  Astroflex's wiring sheet has tach as PURPLE / white. This is what I tried first.  Other's have white, tried this next. Still no go.  I found these wires between the steering column and center console in a bundle that forms a loop.  Is this the correct bunch of wires?  Alternate locations?
Have not did the bypass yet, testing with key in ignition.  Engine starts, but starter does not quit.
Posted By: snguyen
Date Posted: December 30, 2004 at 8:42 AM
TACHOMETERpur/wht or whiteignition module
Ignition Control Module Located On Passenger Front Of Engine In Front Of Valve Cover. WHITE Wire Also Located In 116 Pin Connector Behind Driver Dash To Right Of Steering Column.
Date Posted: December 30, 2004 at 2:52 PM
Just to put in what I found so others can read.  There are three white wires in that bundle.  I had to remove the duct tape (yes, that's what it felt like) that ties the wire bundles together.  The third one I found was the one I needed.  On the Ignition coil connector, the white wire 5th in from the right is the one you need if you want to trace.
