tach
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=46421
Printed Date: April 16, 2026 at 1:57 PM
Topic: tach
Posted By: sounds
Subject: tach
Date Posted: December 30, 2004 at 8:12 PM
I can't seem to find the tach wire for a 2000 chevy s10 , I know the colour wire which is white but i can't locate the coil. Is there somewhere else I could find the tach wire.
------------- puresound
Posted By: auex
Date Posted: December 30, 2004 at 8:34 PM
Here is an alternative location for your tach.
Tachometer - white - PCM
Notes: The PCM is located on the passenger fender. On the 2.2L the wire is in a black 80 pin plug pin 10, and on the 4.3L the wire is in a red 32 pin plug pin 20.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
