2000 GMC and remote starter
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=46481
Printed Date: April 18, 2026 at 12:56 PM
Topic: 2000 GMC and remote starter
Posted By: electra
Subject: 2000 GMC and remote starter
Date Posted: December 31, 2004 at 11:06 AM
Hey guys I really need some guidance from some experts here fast, I'm in the middle of installing a remote starter in my father's 2000 GMC Sierra and I'm unsure of a couple things. I have most of it installed, passkey and all but: Its a Prostart 3300 car starter with GM passkey/VATS, the truck has all the bells and whistles from the factory for this model year. - The starter wire is suppose to be yellow from the ignition harness but the only yellow wires i can find are one that looks to be 22 gauge and runs from the switch to the ignition harness, and another that’s perhaps 20 gauge and runs from the switch to the fuse panel. Which, if any, is the right one? - Parking lights, I have three different sheets that tell me to hook it up at three different places. The one tell me just the light blue wire at the switch itself so I chose this and only hooked up the parklight(+) from the car starter to this, but there is also a parklight (-) from the car starter, do I need this or is it better to wire both at the BCM under the dash? - I'm confused about the arm/disarm and door lock hook up for this vehicle. I've looked at the wiring diagrams on this site and some of the wires don't appear to be where they say the should be or appear to be totally inaccessible. The drivers door pin switch on this truck is in the third door of the extended cab so where in the heck do i find this wire up near the dash? Also two out of the three wiring diagrams i have only list a disarm wire. So please what the heck do i hook up to make this work!!! I'm confused please help. - Door lock activators from the car starter are (-) pulsed but it appears that the connection for this truck require + pluses, is this correct and where do I make the connections? In the drivers kick panel I only see three harnesses two of with appear to connect to a plastic junction, is this just a pass-through wire for wire because the lt green wires for the door locks, I think, appear to come in one end and out the other. What do I hook up for the door locks, the truck does have keyless entry from the factory. Cheers, Chris.
Posted By: KarTuneMan
Date Posted: December 31, 2004 at 12:46 PM
The startrer wire IS a small yellow wire, the other is the passlock R-code wire. The locks are in the module under the dash....brown blug lt.blue and white they are Pos.(+) The disarm is in the purple plug.Its a neg(-) trigger. Lt.green To arm...you trigger the door pin wire after run or with the lock.....ITS A NEGATIVE (-) THOUGH...so I dont no if your remote start has any aux outputs, if it does...use is for the re-arm Does this make sence? | 12volts | red | + | ignition harness | | Starter | yellow | + | ignition harness | | Second Starter | | | | | Ignition | pink | + | ignition harness | | Second Ignition | white | + | ignition harness | | Notes: To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system. | | Third Ignition | | | | | Accessory | orange | + | ignition harness | | Second Accessory | | | | | Keysense | | | | | Power Lock | lt. blue | + | brown plug at BCM | | Notes: The BCM is located behind the drivers side of the dash. The plugs on the BCM face towards the rear of the vehicle. The parking lights are in pin A5 and the headlights are in pin A11. | | Power Unlock | white | + | brown plug at BCM | | Notes: The BCM is located behind the drivers side of the dash. The plugs on the BCM face towards the rear of the vehicle. The parking lights are in pin A5 and the headlights are in pin A11. | | Lock Motor | gray | | drivers kick panel | | Unlock Motor | tan | | drivers kick panel | | Parking Lights+ | brown | | lt. blue plug at BCM | | Notes: The BCM is located behind the drivers side of the dash. The plugs on the BCM face towards the rear of the vehicle. The parking lights are in pin A5 and the headlights are in pin A11. | | Parking Lights- | white | | lt. blue plug at BCM | | Notes: The BCM is located behind the drivers side of the dash. The plugs on the BCM face towards the rear of the vehicle. The parking lights are in pin A5 and the headlights are in pin A11. | | Hazards | | | | | Turn Signal(L) | | | | | Turn Signal(R) | | | | | Reverse Light | | | | | Door Trigger | | - | BCM | Notes: Use tan for the drivers door located in pin B4 of the purple plug, and for the passenger door it will be a orange in pin B2 in the purple plug or dk.blue/white in pin B11 of the lt.blue plug, must diode isolate these wires.
The BCM is located behind the drivers side of the dash. The plugs on the BCM face towards the rear of the vehicle. The parking lights are in pin A5 and the headlights are in pin A11. | | Dome Supervision | | | | | Trunk/Hatch Pin | | | | | Hood Pin | | | | | Trunk/Hatch Release | | | | | Power Sliding Door | | | | | Factory Alarm Arm | | | | | Factory Alarm Disarm | lt.green | - | drivers kick | | Notes: Also found in the purple plug of the BCM. | | Disarm No Unlock | | | | | Tachometer | white | | ECM | | Notes: ECM is located near the battery, down low, between the fender and the fan under the black plastic cover. On the 4.3L, the tach wire is at pin 20 in the connector labeled red. On the 4.8L, 5.3L, and 6.0L, the tach wire is located at pin 10 in the red connector. | | Wait to start | dk. blue | - | instrument cluster | | Notes: See DirectFax document 1090. | | Brake Wire | white | + | brake pedal switch | | Parking Brake | | | | | Horn Trigger | black | - | brown plug at BCM | | Notes: The BCM is located behind the drivers side of the dash. The plugs on the BCM face towards the rear of the vehicle. The parking lights are in pin A5 and the headlights are in pin A11. | | Memory Seat 1 | | | | | Memory Seat 2 | | | | | Memory Seat 3 | | | |
| Immobilizer Bypass Module: | Required: Yes | Type: Passlock 2 | Part #: 555L or 555T | | Notes: N/A | -------------
Posted By: electra
Date Posted: January 03, 2005 at 10:19 PM
Anyone have any idea on this. I've installed a Prostart CT-3300 car starter and PATSK-350 bypass module in my 2000 GMC sierra. All it does when I try and start it is it cranks over for a second or two and doesn't start. It tries to start itself three times doing the same thing. I'm using the second ignition wire output from the bypass module. Everything appear to be hooked up right and programs fine, the tack signal programs fine (I'm using the purple wire off the coil harness for this). I've hooked teh disarm wire to the green wire in the drivers kick (I'm not exactly sure this is the right wire). Everything seems to point towards the passkey 2 not being bypassed but I've tried putting the key in the ignition and trying the remote starter with the same results. Does anyone have some suggestions because I'm stumped.
Posted By: jrilla
Date Posted: January 03, 2005 at 10:39 PM
I would double check your dipswitches. Try a different setting.
You said you tried to start the car with the key in the ignition, but that wont work unless the key is turned to ON. But then most remote starters wont try to remote start with ther key in the on position. One thing i have never tried because i have never had to, but I would think if you pressed the start button on the remote then turned the key to on, the remote starter would try to start, then you would know if it is the bypass. Be sure the bypass module is not being triggered though when you try this. You should be able to just disconnect the ground when running wire from the RS to test this way.
Let us know how it turns out.
------------- J Rilla
Owner/Installer
Posted By: electra
Date Posted: January 03, 2005 at 11:22 PM
Thanks I'll try this. One thing I noticed, doesn't the passlock 2 system lock out the ignition system for ~10 mins if a wrong resistor or no resistor is used? In my case I can start the truck with the key right after a missed start with the remote starter, is this normal or is it just pointing to some other problem causing this other than the passlock module?? Thoughts?
Posted By: kgerry
Date Posted: January 04, 2005 at 9:48 AM
verify you have the correct bypass module for this vehicle... i use the 555L or GMBP with no problems....
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: electra
Date Posted: January 04, 2005 at 9:43 PM
Ok after two bad passlock 2 bypass modules I got it working but I wish I could have bought a 555L instead of this crappy PATSK-350 I got. They don't sell the 555L around here and most install guys won't sell them to the public here so I'm SOL.
Posted By: gus1
Date Posted: January 05, 2005 at 12:32 PM
Double check your resistance measurement, and then, on the bench, power up the module and double check the resistance vs. what the manual tells you. Passlock2 you get a 5% error margin.... not too bad if the car needs to see 13kohms..... not too good if it needs to see 600ohms. I used to bench all of the dipswitch modules before they went into the vehicle. Some were fairly close to the chart, many were in the ballpark, most were somewhere out in the parking lot next to the souvenier stand, so to speak.
Gus
------------- Wherever I go, that is where I end up......
