Boa Remote start - 02 Explorer
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=46609
Printed Date: April 18, 2026 at 10:46 PM
Topic: Boa Remote start - 02 Explorer
Posted By: gforceman
Subject: Boa Remote start - 02 Explorer
Date Posted: January 01, 2005 at 9:29 PM
ok peeps i installed - the Boa remote start Programed OK , i hit start NOTHING - the ring and Bypass box installed - i also installed the same remotestart ( boa ) in a 99 explorer no problems works like a champ  so was there anything i missed like alarm disarm ? i didnt hook it up .. thx
Posted By: snguyen
Date Posted: January 01, 2005 at 11:52 PM
ItemWire ColorPolarityWire Location
12Vyellow+ignition harness
STARTERred+ignition harness
IGNITIONRED / lt. green+ignition harness
ACCESSORYGREEN/ lt. green+ignition harness
SECOND ACCESSORYnone
TACHOMETER*3ignition coil/coil pack
POWER LOCKpink / YELLOW-driver kick panel or CSM *1
POWER UNLOCKpink/lt. green *4-driver kick panel or CSM *1
PARKING LIGHTS +brownheadlight sw or driver kick
PARKING LIGHTS -none
DOOR TRIGGERBLACK/ lt. blue+driver kick panel
HEADLIGHTSRED / yellow+headlight switch
WIPERSwhite(L), blu/org(H)+windshield wiper motor
LF WINDOW UP/DNwht/blk - tan/lt bluAdriver window switch
RF WINDOW UP/DNwht/yel - tan/lt bluAdriver kick panel
LR WINDOW UP/DNgry/org - yel/lt bluAdriver kick panel
RR WINDOW UP/DNyel/blk - RED / blkAdriver kick panel
TRUNK/HATCH PINcommon with doors
HOOD PIN
TRUNK/HATCH RELEASEorg/lt grn or pur/ye+Central Security Module *1
FACTORY ALARM ARM
FACTORY ALARM DISARMGREEN/ purple-driver dr harness or CSM *1
HORN TRIGGERyellow/lt. green-steering column or CSM *1
BRAKE WIREtan/red to lt. green+brake pedal switch
LOCK MOTORpink/blackdriver kick panel or CSM *1
UNLOCK MOTORRED / orangedriver kick panel or CSM *1
DISARM DEFEATpink/orangedriver 'B' pillar or CSM *1
DISARM NO UNLOCKnone
DOME SUPERVISIONuse door trigger
SPEED SENSEgray/blackradio or GEM *2
SUN ROOF OPEN/CLOSEnot recommended
SUN ROOF LIMITnone
LF SPEAKERorg/lt grn-lt blu/whradio
RF SPEAKERwht/lt grn - grn/orgradio
LR SPEAKERgry/lt blu - tan/yelradio
RR SPEAKERorg/red - brn/pnkradio
RADIO 12VWHITE/ yellow+radio
RADIO GROUNDBLACK/ lt. blue-radio
RADIO SWITCHBLACK/ pink+radio
RADIO ILLUMINATERED / black (dimmer)+radio
POWER ANTENNAnone
Notes:NOTE: Some models of this vehicle are equipped with PATS (Passive Anti Theft System). Use DEI module 555U to over-ride during remote start. *1 The CSM (Central Security Module) is below the passenger side 'C' pillar. *2 The GEM (Generic Electronic Module) is behind the glove box above the kick panel. *3 For tach go to one of the ignition coils or coil pack and use the wire that is NOT WHITE/ lt. blue. *4 The GEM in this vehicle shuts down after the doors have been locked for a certain time period, to 'wake-up' the system refer to directfax document #1094.
Date Posted: January 02, 2005 at 12:00 AM
thank you very much ; )
