Viper 791 vx in 2000 silverado
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=46673
Printed Date: April 18, 2026 at 5:23 AM
Topic: Viper 791 vx in 2000 silverado
Posted By: Curtislo
Subject: Viper 791 vx in 2000 silverado
Date Posted: January 02, 2005 at 2:46 PM
Hi everyone, I'm new to 12volt, I'm getting ready to put a viper 791vx into my 2000 silverado. Any help would be greatly appreciated, but my first question is, Do I need the 556U bypass and how does that work? Thanks very much
Curtislo
Posted By: Teamrf
Date Posted: January 02, 2005 at 7:02 PM
No you will use the 555L or the 555T.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Posted By: mobileworks
Date Posted: January 02, 2005 at 7:13 PM
You can also use a code alarm plxr which is super easy to use and program and it doesn't require that you cut the passlock wiring at the steering column.
Posted By: kgerry
Date Posted: January 03, 2005 at 2:16 PM
use the 555L or GMBP... the PLXR is defaulted for Ion's ( which means you'll have to reprogram it, whereas the GMBP is defaulted for Passlock II  )and the 555T has been discontinued ( for a couple of years now )
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: Curtislo
Date Posted: January 07, 2005 at 6:59 PM
Thanks guys I've ordered the 555L and hopefully will start putting everything in this weekend
Curt
