Boa 256b, 2003 honda civic
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=46704
Printed Date: April 18, 2026 at 7:28 AM
Topic: Boa 256b, 2003 honda civic
Posted By: turnup
Subject: Boa 256b, 2003 honda civic
Date Posted: January 02, 2005 at 7:58 PM
Well i am pretty sure all my connections are correct as i went through the manual and the wiring diagram of my 2003 honda civic.
What i am running into is that the power wire going into the "module" is hot. While the power wire coming out has no current.
The car obviously doesnt attempt to start at this point.
Has anyone run into a similar situation and/or have any advice, do i need to give you anymore information.
THanks in advance.
Posted By: astrain1970442
Date Posted: January 03, 2005 at 10:25 AM
Hey turnup I am installing a 265b as well and running into the same issue as you in a 99neon. I've triple checked all the wires. All are correct as per the instructions and still nothing. I hear relays power up when I turn the key on but thats it. There is no response at all from the remote start function, nada.  I'm starting to wonder if the unit is defective. I'm gonna call their tech support tonite and see if they can provide any help..If they provide any useful info I'll post it. Good luck.
Posted By: profuse007
Date Posted: January 03, 2005 at 12:23 PM
shutdown switch all taken care of?
check out my site (on signature) for the 7thgen RS/alarm DIY tutorial to see if itd be any help.
THanks in advance.
Houston,TX
Posted By: turnup
Date Posted: January 05, 2005 at 10:21 PM
Hey, thanks for the replys, helped me out. Yea and I broke a clip on my steering "shroud". woot. Well i'm down to the last thing. I believe my car has a positive polarity for the parking lights and I am assuming i need to install a relay in order for the confirmation flash, is this true? And if so, is there a specific relay that i have to purchase, or is this just a universal thing?
Thanks again!
Posted By: mainormoscoso
Date Posted: January 05, 2005 at 10:35 PM
I did install a boa r/s and had the same problem, the thing is you have to program the remote to the unit, and the batteries on this sistems are discharged you have to get a new battery and then program the remote to unit, disconect the power to the unit and reconect, turn ingnition on and then hit the program button on the remote for 5 seconds, hope it helps
