Commando 2500 & Acura TL strt prblm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=46705
Printed Date: April 18, 2026 at 4:39 AM
Topic: Commando 2500 & Acura TL strt prblm
Posted By: carlmorrell
Subject: Commando 2500 & Acura TL strt prblm
Date Posted: January 02, 2005 at 8:01 PM
I just purchased one of these for my wifes Acura.  I am having a problem with it.  I can not ge tthe remote start to work.  From reading this forum, I think it is because I have not set the engine checking type.  I throught the Green wire would just start it, regardless of engine check setup, my bad. I do have the BLACK/ White wire grounded.
However, I have NOT installed the key transponder.  Should the car start with the remote, if there is a key in the ignition?  Why isn't the transponder plug compatible with the 2500?  I still have not figured out how to hook it up.
If anyone from Commando reads this forum, the manual, connector layout, lack of crimps and looms are a BIG disappointment. Without looms, the installation would look like a rats nest.  I say this as a customer, and a computer engineer that has designed dozens of products.
TIA, for advise, Carl
Posted By: Mobilesecurity
Date Posted: January 05, 2005 at 10:45 PM
I jus did 1 of those 2500's and couldn't get the remote start 2 work. Wut u need to do is change the engine checking type to voltage checking, on these units that works best. And yes, it should remote start with a key in the ignition
check twice connect once
Date Posted: January 05, 2005 at 10:51 PM
Oh and buy the way you can use electrical tape to to put around the wires if you don't have loom. Just wrap all the wires 2gether to make a harness. It looks very nice
Date Posted: January 06, 2005 at 7:12 PM
Mobile security,
Thanks for you help.  I did get it to start (with a key in the ignition) after I set the no start checking. and one second start.  Furtunatly I had a lot of loom of various diameters.
Still waiting for free time to finish the install of the transponder.  Wish me luck!
Carl
Date Posted: January 06, 2005 at 7:36 PM
Mobile security,
Carl
