2002 F-250 Super-Duty Wiring Codes
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=46938
Printed Date: April 18, 2026 at 11:07 PM
Topic: 2002 F-250 Super-Duty Wiring Codes
Posted By: msettl01
Subject: 2002 F-250 Super-Duty Wiring Codes
Date Posted: January 04, 2005 at 10:30 PM
    I am looking for some information to complete the installation of tha remote start system on a 2002 F-250 Super-Duty diesel.  I need the Tach wire. I understand that I am looking for a WHITE/ pink wire but can not find the wire anywhere. I also need the color code and location of the of the Glow Plug light or wait to start light onthe dash.
    I am installing an Omega RX-4 system and need these signals to start the truck in the cold weather that requires longer starter times.
Posted By: KarTuneMan
Date Posted: January 05, 2005 at 2:32 AM
TACH WIRE.....GREEN / WHITE under dash left of steering column. in a bundle of wires behind E-brake handle
WAIT TO START.......white OR white and lt. green @ the glow plug relay under hood pass. side firewall..(little silver box)   POS(+)
Posted By: slammedb5
Date Posted: January 05, 2005 at 5:28 AM
On diesel vehicles the tach wire is green or white, in a 42 pin plug under the clamp on the engine side of the air intake duct. For wait to start  diesel vehicles the wait to start light is activated by a databus wire from the ECM. To do wait to start use a pulse timer relay and follow DirectFax document 1091
