2002 F-250 Super-Duty Wiring Codes
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=46939
Printed Date: April 18, 2026 at 11:27 PM
Topic: 2002 F-250 Super-Duty Wiring Codes
Posted By: msettl01
Subject: 2002 F-250 Super-Duty Wiring Codes
Date Posted: January 04, 2005 at 10:31 PM
    I am looking for some information to complete the installation of tha remote start system on a 2002 F-250 Super-Duty diesel.  I need the Tach wire. I understand that I am looking for a WHITE/ pink wire but can not find the wire anywhere. I have looked in the main wiring harness under the dash and found a WHITE/ pink but the system did not pickup the Tach signal. Nor did I read the correct AC voltage on the wire. I also need the color code and location of the of the Glow Plug light or wait to start light on the dash.
    I am installing an Omega RX-4 system and need these signals to start the truck in the cold weather that requires longer starter times.
Posted By: Rmcknight6
Date Posted: January 05, 2005 at 12:11 AM
Posted By: secureauto
Date Posted: January 05, 2005 at 12:43 AM
Here's a link for your wiring diagram,
2002 Superduty
I did a remote start on a 2002 super duty and I found the tach wire behind the fuse box, the wire will be either pink/white or GREEN / WHITE. There will be a bunch of wires taped together with the ends shrink wrapped.
ASE Certified
Posted By: msettl01
Date Posted: January 06, 2005 at 6:49 PM
Thanks for the information. Once this weather clears up I will try to finish the installation and report the results.
