2WFM-AS on 03’ Accord ex
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=46944
Printed Date: April 19, 2026 at 4:21 AM
Topic: 2WFM-AS on 03’ Accord ex
Posted By: ustankya
Subject: 2WFM-AS on 03’ Accord ex
Date Posted: January 04, 2005 at 11:36 PM
i have a compustar 2wfm-as on my 2003 honda accord ex. every time i press the ( I ) on the remote to lock my door, it gives me additional 3 beeps showing me that the door is open on the remote. which is not. any idea what i mite of done wrong during the install???
and also, my car has remote trunk release, after i have installed my alarm, my truck wont open, not even with the factory remote. do i have to buy an additional device to open my trunk??
you experts out there, any suggestion???
-=(kAo)=-
Posted By: Dhman
Date Posted: January 05, 2005 at 12:41 AM
I'm not too sure about this but I think u have to hook a relay up for the trunk release.  The (-200ma) output on the alarm should be hooked to a relay supplying +12v to the trunk release, on the 03+ accords the trunk release is a YELLOW /GREEN(+) wire and your output is (-) on the alarm system.
Can someone please confirm this??
Omar
Posted By: secureauto
Date Posted: January 05, 2005 at 1:19 AM
It is YELLOW /GREEN (+). If the trunk release doesn't work with the factory remote, you should check for a blown fuse.
ASE Certified
Posted By: ustankya
Date Posted: January 05, 2005 at 6:20 PM
i checked the fuse, its not blown. and my factory remote wont open the truck after i installed the new alarm. any other suggestion? and does anyone know why my new remote beeps 3 times after i lock the door, sayin the my door is open??
-=(kAo)=-
Posted By: profuse007
Date Posted: January 05, 2005 at 6:27 PM
-so, does the trunk work w/ the new alarm on?
-you prolly grab the wrong wire.
|     DOOR TRIGGER|GREEN/ red |- |grn 5 pin plg behind fusebox|
check it w/ a DMM to be sure that its a door trigger.
Houston,TX
Posted By: ustankya
Date Posted: January 05, 2005 at 6:52 PM
the truck wont open with the new alarm either
-=(kAo)=-
Date Posted: January 09, 2005 at 8:38 PM
Have you tested the wires at the trunk? Does the trunk release have an override switch at the trunk?
ASE Certified
