Boa remote start keyless entry
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=47013
Printed Date: May 02, 2026 at 6:03 AM
Topic: Boa remote start keyless entry
Posted By: shaftmaster
Subject: Boa remote start keyless entry
Date Posted: January 05, 2005 at 9:09 PM
I'm trying to install the the Boa (Model 265B) remote start/keyless entry in my 95 mazda protege' LX. I am having a lot of trouble with hooking up to the power door locks, I think they are a negetive multipex and maybe need a resistor, but I just cant understand the little manual. Boa said they had more info online but I cant log in because my "crash code" has "expired". I just need some guidence for which wires to cut, what resistors i need and where to get them.
Thank you for your time,
Robert
Date Posted: January 05, 2005 at 9:11 PM
If you need more info just ask
thank you
Posted By: swamprat323
Date Posted: January 05, 2005 at 9:19 PM
|       POWER LOCK|GREEN / WHITE        |- |passenger kick panel        |
|     POWER UNLOCK|GREEN/ red           |- |passenger kick panel        |
From Alarm
GREEN/ black go to lock wire in car GREEN / WHITE
purple and PURPLE / black go to ground, you dotn need the fuses you can cut them out.
blue/black go to unlock wire in car GREEN/ red
The WHITE/ black and BROWN / black are not used.
Date Posted: January 07, 2005 at 3:24 PM
  It doesn't have an alarm so  "From Alarm" are you talking about the control modual.
just making sure. thanks for the help
Date Posted: January 07, 2005 at 3:25 PM
and do I need any resistors
Date Posted: January 07, 2005 at 6:29 PM
The Brain, keyless unit, no you dotn need resistors.
