starter range
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=47144
Printed Date: April 29, 2026 at 6:24 PM
Topic: starter range
Posted By: steve700xedge
Subject: starter range
Date Posted: January 07, 2005 at 2:28 PM
hello, I installed a commando fm-870 in my '03 chev silverado and the remote range sucks bigtime like maybe 150-200 ft, any suggestions as to the cause or something to check to remedy this. it is a two way remote that advertized 2500ft range. thanks for your time    steve
2003 silverado2500HD LT crew cab
Posted By: jaurora
Date Posted: January 07, 2005 at 3:07 PM
You want the antenna to be as low to the bottom of the windshield as possible. Some newer model GM vehicles have somewhat of a metallic/magnetic coating. The lower the antenna the better the reception on this vehicle. Also while trying to use the remote in some areas such as houses buldings ect will dramatically cut down on the distance. Similar to "dead zones" on cell phones. Also note that the specified range noted from the manufacturer is good on non obstructing open space on a clear day.
Let me know if this helps any.
MECP certified (If it really means anything)
Jeremy
Date Posted: January 08, 2005 at 9:38 AM
tried it in the open but the range is no wherte it should be, has anyone ever had a defective antenna or could it be the unit itself. I'm ready to send it back and get a $50 dollar cheapo it worked from a atleast 500ft in my last truck.
Date Posted: January 08, 2005 at 3:37 PM
help please
Posted By: gus1
Date Posted: January 08, 2005 at 4:32 PM
How's your ground?
Gus
Date Posted: January 08, 2005 at 9:32 PM
i'm assuming its ok but I will check tomorrow, are you referring to the groung on the alarm/rs itself thanks for your time
