2003 Ford Exporer remote starter
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=47351
Printed Date: April 18, 2026 at 9:44 PM
Topic: 2003 Ford Exporer remote starter
Posted By: jayyzr
Subject: 2003 Ford Exporer remote starter
Date Posted: January 10, 2005 at 9:58 AM
On a 2003 Explorer If I wanted to hook up a remote starter, it has a keyless entry already, I would only need a transponder bypass to be able to start the car right?.... one other thing not all Fords come w/the PATS system right, If not can't you look @ the key and know if they have one or not or would I have to check w/ the dealer thanks
Taking It 1 Wire @ A Time...
Posted By: KarTuneMan
Date Posted: January 10, 2005 at 10:09 AM
in 2003 I doubt you'll find one that DOESN'T need a bypass. If you have a steel key with NO PLATIC HANDLE, and you can start the rig..........no bypass needed. Heres a link for some tech...
https://www.directechs.com/directwire/wire_body.asp?action=select&yr=5258&product=Remote%20Start
Posted By: jayyzr
Date Posted: January 10, 2005 at 10:14 AM
