Climate control on 2005 Scion XB
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=47391
Printed Date: April 19, 2026 at 1:19 AM
Topic: Climate control on 2005 Scion XB
Posted By: 996 pilot
Subject: Climate control on 2005 Scion XB
Date Posted: January 10, 2005 at 7:17 PM
Hello,
Does anyone know if the blower motor and A/C will turn on with the 2nd ignition or the accesory on this car, or will I have to run a relay to get the blower motor to work? Also is the defroster hooked into the 2nd igniton or will it need a relay as well. I want to install a Viper 791 unless anyone can recommed something better. Thanks
Posted By: KarTuneMan
Date Posted: January 11, 2005 at 3:04 PM
https://www.directechs.com/directwire/wire_body.asp?action=select&yr=5716&product=Remote%20Start#
Check your wiring against this tech sheet. For the most part, these are simple cars to do.......They are laid out SMART, just like their Toyota big brother.
You have 2 IGN.   and 1 ACCS. they all gotta get fired up!!    Just for laughs, see if there isn't another ACCS. wire.
AND, are you talking about the REAR window defroster........go to the switch and test CAREFULLY
I would ALLWAY say....find an Astroflex dealer...the stuff is bullet proof!
Date Posted: January 11, 2005 at 7:29 PM
Thanks I will try it.
